Question
Springville, Tn
1989 Ranger 333v - 1995 Evinrude 130 hp
What is the difference between static thrust and lift in a prop?
And if rake increases bow lift,why also does my stern rise so much with the merc chopper,is it part boat design,as the jaguar has a very steep deep transom.Tends to run rather flat with trim barely above nuetral position?
Bent nose also makes it seem its not trimmed out as well but thats looks not reality.Bend is level when trimmed ,not dipped or raised .
Rooster tail non existant,runs a ft or so higher for 20 ft behind the boat,like a huge long swell.,with very little spray.
[/IMG]
Had just pulled it out of a mud hole,I did clean her up
