- Jan 17, 2011
- Riverview,MI
Finally got my 11 Z7 home monday. Put it in the water at the dealer the trim gauge was off. The mech tried to adjust it and it quit working. They put another ground strap on the motor after calling Nitro thinking the grounds didnt get taped off well enough when painted. seemed to be fine. Brought it home, put it in garage. went out there today, turned the key on to see how the dimmer switch worked and no power at the ignition. Also no power at the trim on the throttle or up front on the bow but it works fine on the motor. power good to the fuse block when the power switch is on. Tried tapping the motor over with key and nothing. Any help would be appreciated, I'm p!$$ed and the dealer is a two hour drive away. Hate that this is happening but I'd rather try to find it then spend 60.00 in gas and wait another week before I can get there
