- Aug 27, 2011
- MN
59 mph (gps) @6000 rpm (5600 is my peak) with a FULL load. 78 deg ambient low humidity. I have run this prop in 85 deg high humidity and it still pulled too many rpm. It runs about the same as my 24 Trophy but the 24 is a couple mph faster.
20 psi water pressure. Roost is cowl high. prop to pad is 3.5" (maybe 3.25, I need to check it again). Holeshot is good loaded.
Apparently, I could turn a 26 right now. Can you work my 25 to bring down my rpm and give me a few more mph? I don't want to buy anymore props. I'm going to take this one off and put my TXP on now and finish the year on that.
