1. Welcome to BBM , We hope you enjoy your stay! Registration is FREE!
    Dismiss Notice
  2. Dismiss Notice
Hard steering left on plane 1999 150H.P. Merc
Discussion in 'Boating Safety and Safety Equipment' started by PeteD, Apr 3, 2017.
  1. PeteD
    Offline
    PeteD New Member
    May 19, 2009
    23
    0
    Norrthern California
    Im back in a carburated boat, Champion Fish & Ski 181 rack and pinion steering, the boat is hard turning to the left on plane only, I thought it could be because there is no torque tab (anode) behind the prop, do I need to add one? tried to purchase what is recommended at west marine but it was to close to the prop when I added it I believe it calls for a 31640T.
    Thanks in advance for replies.
  2. remington
    Offline
    remington Champion Boat Officer BBM Staff Member
    Aug 30, 2009
    2,003
    98
    Missouri
    What's your boat set up? Jackplate, Prop to pad, prop/make/pitch and RPMs at wide open throttle and trimmed all the way up? What year is your champ?
  3. PeteD
    Offline
    PeteD New Member
    May 19, 2009
    23
    0
    I believe my prop is a trophy P24, Also says Champion on it, not sure of prop to pad measurement , no jack plate, the year is a 1999, I believe the rpm is 5000.
  4. remington
    Offline
    Aug 30, 2009
    2,003
    98
    Missouri
    That's a tad to much wheel for the 181 FnS. You'll want a 23 Tempest or 23 Trophy. Should be spinning them around 5800 RPM and high 50 MPH.
  5. PeteD
    Offline
    PeteD New Member
    May 19, 2009
    23
    0
    Thanks, I just went and looked at the prop and its a tempest plus 23p.
  6. remington
    Offline
    Aug 30, 2009
    2,003
    98
    Missouri
    Right wheel. Check your compression and if it's good it's most likely your set up or your driving. Since you have no jackplate go check and see what hole the motor is mounted to the transom. You should be "second hole up" meaning there should be about an inch of space between the top of the transom and engine mount. Or check and see if you have ANYTHING disrupting the water flow from the pad to the prop like transducers or ladders ect. For top performance you should drop the hammer, get on plane, trim it ALLLLL the way up and wide open throttle.
  7. PeteD
    Offline
    PeteD New Member
    May 19, 2009
    23
    0
    Will do .
    Thank you
  8. PeteD
    Offline
    PeteD New Member
    May 19, 2009
    23
    0
    the engine is mounted in the third hole, (6 holes total) the top of the engine mount is about an inch above the transom
  9. PeteD
    Offline
    PeteD New Member
    May 19, 2009
    23
    0
    the engine is in the third hole (total of 6) the top of the engine mount is about an inch above the transom
  10. Thread Status: You only have permission to view the first post in this thread.
Loading...
Similar Threads Forum Date
Steering wheel getting hard to turn Bass Boating Tips Feb 9, 2016
Richardson Wins 2017 Eastern Qualifier North Carolina Today at 8:25 AM
Laus3 Quit Setting the Hook so Hard! Humor Hole - Off The Hook!! Aug 5, 2016
The waiting is the hardest part Casting Cuties Jul 22, 2016
Welcome, Richard Mann Welcome To Our New Members Jan 15, 2016
Share This Page
