Hi boaters! It's time to start cleaning your lures and sharpening those hooks. This year might prove to be a great one. There's a lot of fish out there just waiting to be snagged and sometimes, fingers, hands, arms, legs thighs, knees and an occasional rear end.
The most common accident during fishing season involves hooks. The second most common hazard facing anglers is getting too much sun. Both are easily avoided. Sunscreen and a hat will handle the sun and a first aid kit with a little knowledge of how to use it will take care of the hook problems.
The most important tool any angler should always have with him/her for removing a hook is a sharp pair of wire cutting pliers. I keep a pair in a zip lock plastic baggy to keep it from rusting. I never use it for anything except for emergencies. I have a duplicate pair in my tackle box for other uses.
Here are a few methods for removing hooks.
When a hook's point and barb are protruding out the skin, it's easier to cut off the barb and back the hook out of the wound - this is when those sharp wire cutters come in handy.
The best method that seems to be recognized by most experienced hook-remover professionals and even by some doctors is called the snatch method. No matter where the hook ends up this method works.
This method is quick, simple and relatively painless, as long as you get it on the first try. The secret to a first time success is yanking the loop of line, which is wrapped around the embedded hook, rather hard so the hook comes out on the first try. The reason you should get it out on the first try is obvious, the patient might not stick around for a second try.
The snatch method of hook removal is simple and effective, It's the best method to remove a hook that's deeply imbedded in the skin and when the barb is buried.
To perform the snatch method when the barb is imbedded, all that's needed is a short length of fishing line, at least 10 pound test, approximately 2 feet long.
1) Remove hook from lure.
2) Double the fishing line and loop it around the hook, as close to the skin's surface as possible.
3) Hold onto both ends of the doubled line, wrapping them around your hand for a firm grip and holding the line parallel to the skinÕs surface in line with the hook.
4) With your other hand, press the eye of the hook down onto the surface of the skin and back toward the hook's bend, as if trying to back the hook out of the wound.
5) While pressing on the hook eye, yank the line sharply, parallel to the skin and in line with the hook, to snap the hook back out of the wound.
6) Apply antibiotic ointment, bandage wound and check to make sure tetanus shots are current.
A basic onboard first aid kit for anglers should contain sunscreen, small bottle of hydrogen peroxide, alcohol wipes. bandages, gauze, tape, hydrocortisone cream for poison ivy and other itchy rashes, antibiotic ointment (Bacitracin or Neosporin) and aspirin. Another essential should be a brand new pair of needle-nosed and wire cutting pliers, sealed in a seal-lock plastic baggy. Anglers using worms should think about up-dating their tetanus shot. The tetanus germs are usually spread in soil.
Lets go fishing and get that big one that got away last year
