I use Sufix 30 lb ,while others here tend to use a heavier line to walk a frog.
I use mostly frogs that walk out of the box regardless of what one uses to throw them with,
So the 30pd is quite heavy enough,and casts a very long way.
Even have one rod rigged with this for top water,while its not a strecth type line its on glass rod thats quite bendable,makes for long casts with a gsplash.And thanks to the line havnt lost a one on it,did get some wipers to take them on the strike when using mono.And they are fairly expensive.
No problems with hookups or tearing mouths as rod is forgiving .
