The NEW DAIWA 2025 KAGE SV TW Baitcaster
DAIWA has added its first baitcaster to the KAGE collection with the new KAGE SV TW 150 baitcasting reel. This compact and adaptable reel is loaded with DAIWA’s newest and most sophisticated reel technologies, the SV Concept and HYPERDRIVE Designs. The SV Spool on the new KAGE SV TW is a 34mm A7075 spool that offers a ton of casting control. The SV(Stress-Free, Versatile) design interacts with the braking system during the cast to give maximum control while at the same time increasing the cast’s distance. The KAGE SV TW’s second big feature is the HYPERDRIVE DESIGN. Initially, it was only for the highest-end baitcasters from DAIWA, but now, with “trickle-down technology,” the HYPERDRIVE DESIGN is available in the mid-range KAGEs. This combination of advanced manufacturing techniques, HYPER ARMED HOUSING, HYPERDRIVE DIGIGEAR, and HYPERDRIVE TOUGH CLUTCH significantly increases your reels’ performance and lifespan.
DAIWA 24 Coastal SV TW 150 Key Features
The post The NEW DAIWA 2025 KAGE SV TW Baitcaster appeared first on OutdoorHub.
- SV Technology – A SV (Stress-Free, Versatile) 34mm A7075 aircraft-grade spool designed for casting control. The spool design and interaction with the braking system give max control and increase casting distance.
- Hyperdrive Armed Housing – A distortion-proof aluminum frame that keeps gearing in perfect alignment and improves the lifespan of the reel.
- Hyperdrive Digigear – A technology that makes gear teeth more efficient at transferring power, resulting in a smoother, more powerful gear set that reduces gear noise. Larger teeth strengthen the gears in the traction wheel.
- Hyperdrive Tough Clutch – The clutch mechanics have been optimized to remain safely in position even on hard casts.
- T-Wing System (TWS) – An innovative “T” shaped mechanical aperture, unique to DAIWA, that the line passes through when casting and retrieving baits, which allows the line to flow freely,
- CRBB – DAIWA’s CRBB ball bearings are shielded to seal out sand, fine grit, salt crystals, and other abrasives for a longer life. Making them 12 times more corrosion-resistant than standard ball bearings.
- Ultimate Tournament Drag (UTD) – The sophisticated drag system uses carbon washers, alloy, stainless steel drag plates, and special lubricants to provide smooth performance. UTD prevents sticking when dragging starts and stable drag for the duration of fighting a fish.
- Zero Adjuster – The spool tension knob comes ideally preset at the factory to match the model and reduce backlash when casting into the wind or with lighter lures. However, anglers can fine-tune the spool tension to their personal preferences.
- 90mm SWEPT HANDLE– The increased torque turns the barrel with greater ease. Features an I-shaped premium cork knob
- Left or Right Hand models are available, as well as high-speed models.
- Gear Ratio – 7.1, 8.1 (High-Speed Models)
- Line Per Crank – 29.8″, 33.9″ (High-Speed Models)
- Weight – 7.1oz
- Max Drag – 11lb
- Reel Size – 150
- MSRP – $259.99
