The G-SOX Rod & Lure Cover – The Rod Sock Improved
G-SOX is here at the NOEoutdoors North Georgia Fishing Expo with a new rod organization and protection solution, the G-SOX Rod & Lure Cover. As anglers themselves, they know that transporting uncovered rigged rods or storing them in a boat can make for a tangled mess. So wanting a better option than traditional rod socks, which easily snag on exposed hooks and lures, G-SOX made their Rod & Lure Cover. A simple but effective product that combines a mesh rod sock with a UV-coated clear plastic tube to fully cover a rigged fishing rod. Making transporting rigged gear either at the start of your day of fishing or at the end of it easy and snagless.
The G-SOX Rod & Lure Covers can work with both baitcasting and spinning reels, though certain spinning rods might not be compatible depending on guide size, and can fit rod lengths of 7′, 7’3″, and 7’6″. Custom sizing for the rod & lure covers is also available, but there is a minimum order of 6 pieces. Additionally, the G-SOX Rod & Lure Covers feature a silicone rubber ring that pads the edge of the tube to prevent the plastic from rubbing on your line and reels and a loop of bungee to help you secure the rod & lure cover to your reels. The G-SOX Rod & Lure Covers are available in red, blue, black, and green, with an MSRP of $14.99. If interested ,you can buy these directly through G-SOX here.
G-SOX Rod & Lure Cover Key Features
  • UV-Coating on the Lure Tube to protect your lures from the Sun.
  • Features a Silicone Rubber Ring pad for the rim of the tube. The rubber ring can be taken on or off with personal preference.
  • Adjustable bungee loop to secure the cover to your reel.
  • Custom Sizes are available with a minimum order of 6.
  • Colors – Red/Black, Green/Black, Blue/Black, Black
  • Size – 7′ to 7’2″ Rods, 7’3″ to 7’5″ Rods, 7’6″ to 7’8″ Rods
  • MSRP – $14.99 per Rod Sock
  • Available – Now
The post The G-SOX Rod & Lure Cover – The Rod Sock Improved appeared first on OutdoorHub.
