Problem solved‏
Problem solved!
Here's a solution to all the controversy over full-body scanners at the airports;
Have a booth that you can step into that will not X-ray you, but will detonate any explosive device
you may have on you.
It would be a win-win for everyone, and there would be none of this crap about racial profiling and this method would eliminate a long and expensive trial. Justice would be quick and swift. Case Closed!
This is so simple that it's brilliant. I can see it now: you're in the airport terminal and you hear a muffled explosion.
Shortly thereafter an announcement comes over the PA system, "Attention standby passengers: we now have a seat available on flight number..."
