- Feb 27, 2009
- Milan, NY 12571
Installed the posi flo fuel pump, and its making more noise than I would like it.
Sounds like someone is hitting with a hammer, noise get butter after fuel water separator got filled, but still hear it, tomorrow I'm connecting water hose and actually run motor, maybe is just air trapped inside fuel line, hope is not because I mounted pump on a plank that connects both sides of boat just under wash well. when I run it dry for couple seconds was quite, if this noise is normal than will put it on a momentary push switch rather than the ignition wire. Any ideas?
