- Apr 27, 2010
- Bethlehem, Georgia
Outboard Motor Selection
It is important to select a motor that is a good match for the hull in terms of power and shaft length.
Power Requirements
Overpowering is a dangerous condition and underpowering often results in a boat that is incapable of performing in the role for which it was acquired. Boats built in the U.S. have a Coast Guard Rating Plate which specifies the maximum recommended horsepower for the hull. A motor with less than 75% of the maximum will most likely result in unsatisfactory performance.
Shaft Length
Outboard motor shaft lengths are standardized to fit 15-inch, 20-inch and 25-inch transoms. If the shaft is too long it will extend farther into the water than necessary creating drag, which will impair performance and fuel economy. If the shaft is too short, the motor will be prone to ventilation. Even worse, if the water intake ports on the lower unit are not sufficiently submerged, engine overheating is likely, which can result in damage beyond economic repair.
Power Requirements
Shaft Length
