[ICAST 2024] The HydroScaler – A Cleaner Fish Scaler
Scaling fish can be a pain and a mess but sometimes it’s a necessity for a whole fish recipe, so walking around ICAST 2024 I found a neat little fish scaler that could help with both factors, the HydroScaler. This is a water-powered fish scaling tool that advertises an easier and cleaner time scaling fish. Using the same concept as peeling eggs under running water, the HydroScaler uses water to help lift the scales away from the body of the fish and then washes them away. It is a relatively simple tool made of lightweight hard plastic with an angled head at the front with no sharp edges or teeth involved like traditional fish scalers. This unique design helps remove the fish scales without damaging the skin of the fish, as well as keeps your hand further back away from any spines. After you are done scaling your fish the Hydro Scaler also works as a standard hose nozzle and can be used to clean up your fishing cleaning table.
The HydroScaler fits on any standard hose so should work in any fish-cleaning setting with a hose connection. This fish scaler being made of plastic also makes it easy to clean after use and corrosion-free even with saltwater exposure. The HydroScaler can be found online for purchase now and has an MSRP of $39.95
HydroScaler Key Features
[ICAST 2024] The Hydro-Scaler – A Cleaner Fish Scaler
Special thanks to the Hydro-Scaler staff here at ICAST 2024, and stick around for more ICAST 2024 coverage.
The post [ICAST 2024] The HydroScaler – A Cleaner Fish Scaler appeared first on OutdoorHub.
- Harnesses the power of low-pressure water to help remove fish scales
- Keeps scales from flying around and sticking to wherever you are scaling fish
- Finger safe, no sharp edges that can cut your wet hands
- Made of high-end plastic, lightweight and corrosion-free.
- Connects to any standard hose for use outside or in the kitchen
- MSRP – $39.95
- Available Now
