[ICAST 2023]FITEC International Adds New Cast Net to Signature Series
FITEC International came to ICAST 2023 two show off a couple of new cast nets they have added to their Signature Series line of Cast Nets. Having been in the cast net game since 1984, they are now the largest cast net manufacturer in the United States and continue to be an industry leader year after year. The first of the two new cast nets is the Signature Shallow Series Cast Nets. Purpose-built to be used in shallower water to catch bait that’s say run up on the bank or beach. Lighter and easier to throw it has a lead line with 1.2 pounds of lead weights per radius foot. They are available in a 10ft and 7ft option with a mesh size that starts at 1/4″ and goes up to 5/8″. Like all the Signature nets, these are made with 6 panels of premium Japanese netting that has excellent tensile strength but are still super supple and soft. The braille lines are pre-stretched 100lb monofilament and attache to a heavy-duty brass swivel.
The second of the two Signature Series Cast Nets is the Deep Water Taped Cast net. Instead of being used for catching bait shallow, this is a net for catching bait sitting deep in the water column. The first and most obvious change is the tape going all the way around the net, this spreads the net out when it sinks instead of bunching up due to the drag in the water. The second feature is a heavier lead line with 1.6 lbs of lead per radius foot. Like the other net this uses the same premium netting and parts. They both come with the FITEC exclusive Net Replacement Policy. If you destroy the net somehow, they will do a one-time replacement of the same model of cast net for 50% off the original price.
Signature Series Shallow Cast Net Key Features
Signature Series Deep Water Tape Cast Net Key Features
Special thanks to the FITEC International staff here at ICAST 2023, and stick around for more ICAST coverage. Also, let us know your thoughts in the comments below, we appreciate your feedback.
The post [ICAST 2023]FITEC International Adds New Cast Net to Signature Series appeared first on OutdoorHub.
- Extremely strong, premium Japanese netting with high-tensile strength
- Generous six-panel design for maximum spread – lies completely flat!
- Double lead-line, triple tied at each mesh to protect the netting
- Closely-spaced marble lead weights to create an even-sealed footprint no bait can escape
- 1.2 pounds of lead weight per radius foot
- Heavy-duty brass swivel
- Double selvage at key stress points for added strength and durability
- Large open horn to reduce tangled braille lines and provide less resistance during throws
- 35-foot high-floating braided poly hand line
- Pre-stretched 100-pound test braille lines with above-average industry count
- 10 ft of 7ft radius options
- Mesh – 1/4″- 5/8″
- Available – Now
- MSRP – $214.22 – $281.10 depending on net diameter and mesh
- Closely-spaced marble lead weights to create an even-sealed footprint that no bait can escape
- 1.6 pounds of lead weight per radius foot
- Taped above the lead line for a wider net spread in deep water
