Force Motor Reassembly
Pkoerner
Indiana
Hello all-
I recently purchased an old Norris Craft what had a Force 125 motor hanging off the back of her. The motor looks to be in good condition and when I picked her up the carbs were off along with the lower unit.
So I had a few questions...
1) What fuel mix do I run with this motor? Its a 1987 125 hp model 1254X7A.
2) Putting the lower unit on, what oil do I need for it? Does standard lower unit oil work?
3) I have to put the impeller housing back together. Which way should the impeller spin (CW/CCW)? I see that it will have a definite "swirl" going one way or the other. Also, some diagrams I have noticed have a gasket between the impeller housing and the back plate and others do not. Which ones are right?
thanks,
PK
