Fitzgerald Fishing’s NEW Stunner JDM Design Series Fishing Rods
Fitzgerald Fishing has brought a new set of JDM fishing rods to the NOEoutdoors North Georgia Fishing Expo, the new 2025 Stunner JDM Design Series of four casting rods and two spinning rods. This limited series of JDM fishing rods is loaded with cutting-edge features and crafted with meticulous attention to detail using some of the finest materials available in Japan. All the Stunner JDM Design Series rods feature an ultra-lightweight advanced carbon fiber 3k monolithic handle. This cuts the weight of the rod down while at the same time transferring even the lightest strike into an angler’s hand. While the rods being lightweight is necessary, the balance and grip of the rods aren’t sacrificed for it. These perfectly balanced rods come with non-slip grips so that you can fish all day comfortably.
Beyond the grips of the rods, each rod has a high-quality lightweight set that minimizes the friction of your line going through them to maximize casting distance. The casting rods have eight guides plus the tip, except for the 7′ Med Hvy rod (9+tip), and the spinning rods have nine guides plus the tip. All six models of Stunner JDM Series of rods have an MSRP of $279.99; these are all available now directly through Fitzgerald Fishing for a limited time until they sell out.
Fitzgerald Fishing Stunner JDM Design Series Rods Key Features
  • Ultra-Lightweight Construction Features an advanced carbon fiber 3k monolithic handle, giving the rods exceptional sensitivity and responsiveness.
  • Superior Strength and Durability Built to last long seasons on the water, providing unmatched strength and durability.
  • Ergonomic Design Comfortable non-slip grips and perfectly balanced for superior comfort and control on the water.
  • Precision Guides High-quality, lightweight guides for minimal friction and maximum casting distance.
  • Stylish Aesthetics Sleek and sophisticated design that reflects Japanese rod-making artistry and craftsmanship.
  • Rod Lengths – Casting (6’8″, 7’0″, 7’0″, 7’3″) Spinning (7’3″, 7’6″)
  • Rod Power – Casting (Med Hvy, Hvy, Med Hvy, Med Hvy) Spinning (Med Hvy, Med Hvy)
  • Rod Action – Fast
  • Rod Guides – Casting (8+1, 8+1, 8+1, 9+1) Spinning (9+1, 9+1)
  • Rod Line Weight (lb) – Casting (8-15, 10-20, 8-15, 10-20) Spinning (8-15, 8-15)
  • Rod Lure Weight (oz) – Casting (3/8-3/4, 3/8-3/4, 1/4-3/4, 1/4-3/4) Spinning (1/8-3/4, 1/4-3/4)
  • MSRP – $279.99
  • Available – Now
The post Fitzgerald Fishing’s NEW Stunner JDM Design Series Fishing Rods appeared first on OutdoorHub.
