- Apr 22, 2010
- BumFu*k, Egypt
Dropshotting 101: Dropshotting In Shallow Water
By Craig De Fronzo
The following article is the first part in a series of tech articles focusing on how to increase your catch. This series will outline all tackle and methods to put you on to more fish. It is a small part of my approach catching more bass on a consistent level.
Every five years or so it seems, a single bass technique comes along and revolutionizes the sport. See Tube fishing, Carolina Rigging (yuk), Slider Fishing and Split shotting to name a few. These days drop shot or down shot fishing is getting any attention that the Senko isn't. Although not a new method by any means, drop shotting has taken a firm hold on Western anglers and has manufacturers scrambling to build drop shot-only baits.
As I stated, drop shotting, in principle is not a new technique. It dates back a long ways in the salt water circle. Although most drop fishing utilized a dropper loop rather than a hook tied directly to the main line, the idea of a weight below the bait is the way people have fished for flatfish for eons.
I remember fishing plugs for stripers with a teaser tied 14 inches above my diver . I tied a straight shank worm hook directly to the main line and set up a 4" Kalin's grub that often got the attention of a hungry striper.
As far as bass fishing is concerned, down shotting began in Japan years ago. You see, over there, water is at a premium. They have relatively few bodies of water. Small lakes see intense pressure with hundreds of anglers competing in tournaments. Anglers fish almost elbow-to-elbow in these deep clear waters. Drop shotting became the method of choice to catch these highly sought after fish. Western Pro's like Don Iovino and Aaron Martens learned this method and began to perfect it on their home waters. A few major tournaments have been won on it as well.
When you read about drop shotting, you often see it described as a great deep water approach for clear waters. In fact, pick up any magazine that talks about the gin clear waters out West and you'll likely get a lesson in drop shotting 101. Anglers team up their electronics and drop shotting for presentations as deep as 100ft. I know it works, but deep vertical fishing isn't my bag. I recognized the fact that this method was as versatile as they come very early on.
I've been tinkering with it since the 2000 season, modifying it to fit my fishing needs and my geographic limitations. Living on Long Island in New York, one must understand that the vast majority of bass water is quite shallow. Sure there are a few places one could go to drown their baits in 50 plus feet of water, but you really have to go out of your way for that.
I had begun to think of the drop shot on a different level, a horizontal level. For the sake of this article, lets consider 15ft of water to be the deepest end of our shallow water fishing. I have come to rely heavily on the drop shot rig in water from 10 inches in depth all the way to 15 feet in depth.
Now, because we are fishing the rig in fairly shallow water, it becomes important to reconsider its mechanics. Here, you would be seriously limiting yourself by fishing it vertically. I liken it to ice fishing in extremely shallow water, there is no point. The horizontal presentation is something bass see on a regular basis from anglers chucking plugs, spinnerbaits and a host of other baits.
The obvious question here is, why fish this rig in place of a split shot, mojo, Carolina or Texas rig? The answer is simple. When you stop retrieving a bait using any of the standard methods, the bait falls to the bottom. With the drop shot, it hovers in place without moving. This can be a huge advantage. One can hover a bait above a weedline or pause the bait on the edge of a weedline or bed. The bait looks and acts alive. I've been into the finesse movement for a long time. I rely heavily on Split shot and Mojo rigs. The past several years have seen me using the Drop shot in place of those rigs.
RODS
In my opinion, Drop Shotting is a true finesse technique. Sure, some big name guys will win a big name tournament throwing an 8-inch worm in 6-feet of water using a 1-ounce weight. It will happen, but it will be the extreme rather than the norm.
For the basis of finesse, I use spinning rods for all of my drop shotting. You certainly do not need the $400.00 Yamamoto or Loomis rods to experience consistent success with this rig. I fish products I can afford.
For shallow water drop shot fishing, you would be hard pressed to find a better rod than a Kistler California series 6-9 ML Drop Shot rod. This rod has all of the backbone you need and a soft tip. It is sensitive as strikes are telegraphed through its IM7 blank. It is light and comfortable to fish with all day. I have also used a 7 foot Kistler Helium LTA that was good as well. This rod gives me a little more leverage when I need it.
For bank fishing or wading I go even smaller to a 6 foot UL model. Let me stress that this is for fun fishing. On a boat, you want a longer rod that moves more line with less effort.
My shallow water presentation focuses on using light liner, light weights and small baits. This would make bait casting gear inefficient and down right difficult to use.
REELS
I am a huge fan of the Shimano Stradic series. I particularly like the 2500 MGf. This reel is the perfect compliment to the 6-9 ML Kistler. This reel has great drag smoothness and line capacity. It features smooth gears and infinite anti reverse. If you maintain it, it will not fail you. I don't dunk my reels so I can't comment on its performance if it is submerged. I can say I have seven of these reels and I've not had a problem with any of them. It is as infallible a reel as they come. Line seems to strip off a spinning reel much easier than a bait casting reel for this method. Free spooling a bait down is time consuming and has to be done right to avoid snarls with casting gear.
LINE
I am a huge fan of Yo-Zuri line. That is my optimum choice. I don't use Berkley, Stren or any other for that matter. The only exception being Tectan and Power Pro for my bait casting work.
For drop shot fishing, I prefer 6- or 8-pound test. These diameters will not cause any memory problems on your wide arbor spools. Standard Hybrid line, despite being a copolymer/Fluoro mix, won't coil up all that much. If you go any heavier, you might see some birds' nests.
I like either the smoke or green lines for all of my fishing. I also use Super Silver Thread which is a very limp, thin diameter line. This one usually comes into play when I'm not tournament fishing.
WEIGHTS
There are several options for applying weights to a drop shot rig. I prefer the swivel clip weights made by Owner called Down Shot weights. These are small bell shaped sinkers with a swivel clip that keeps the line is place without slipping. I use them in the following sizes: 1/16oz, 1/8oz, 3/16oz and 1/4oz.
XPS weights are similar. They are made by BPS but feature a cylindrical shape that comes through just about any snag with ease.
I don't see the point of using tungsten here, I expect to lose a few weights so high-priced tungsten would not be an economical choice nor is it an advantage.
To employ the drop shot on a horizontal plane in shallow water, I rely on lighter weights. Despite the 1/16oz and 1/8oz sizes, I have no problems keeping in contact with the bottom. These lighter weights hang up less than heavier ones and I feel are an advantage once the fish picks the bait up. They likely seem natural as a fish drags the rig.
There are other options besides the clip weights. You could use a split shot weight or peg a bullet weight. These options in my opinion are inferior.
TYING THE RIG
The drop shot rig consists of a Palomar knot with a really long tag end. To tie the rig, make sure you point the hook up so that the point is closest to the rod tip. Tie your knot and pull the tag end around through the hook eye. This will force the hook to stand 90 degrees from the line and it will keep the bait straight.
As far as leader is concerned, I prefer about 12- to 14-inches for most applications. In shallow water, I try to figure out how far off the bottom the grass is growing. If it grows 10 inches off the bottom, a 12- to 14-inch leader is perfect for suspending the bait just above the weeds. This gives bass a good look at the bait.
To secure the clip weight, simply make a small overhand knot at the bottom of the tag end. I have experimented with the pre tied rigs but usually became frustrated or disappointed with them. They come coiled and are a pain to straighten out. They are also affixed to the main line by a snell which weakens very quickly.
WORKING THE RIG
Since this is a horizontal presentation, it is a method where we are going to drag the rig on the bottom. There are two thoughts regarding retrieve when fishing a drop shot rig, movement or no movement. At different times I employ both.
I like to work this rig slowly. Movement is minimal yet I often find myself ever so slightly jiggling the rod so the tip bounces about an inch or two. This is a very controlled, and minimal movement. This gets the bait wiggling slightly. I must over emphasize that if you where watching me do this movement from another boat, you would not be able to detect it.
As I work the bait, I keep the line taut. This allows me to tell what is going on under water. I can feel differences in the bottom.
If you are new to a technique, the obvious obstacle that you must overcome is learning what the bait or rig feels like when you fish it. This can be a process of uncertainty. It is so hard to go out and fish a rig for the first time and expect good results. I've always advised people to learn what the rig feels like and when you fish it, if you feel something different, you likely have a bite. This is what I refer to as "weighing the line". Learn what the rig feels like on the end of your line. Anything lighter or heavier is a strike.
The way I fish this rig, I would compare it to working a Carolina Rig or Split Shot rig. My approach is much slower. I make short pitches about 25 feet in front of my boat and I visualize a target zone that I want to bring that rig through. It may be only a few feet long. Once I get through the zone, I reel in and cast again. I do not fish this rig back to the boat.
I opt to use this rig anytime I think bass are relating to baitfish that are situated close to the bottom.
DETECTING THE STRIKE
If you learn how to weight the line, you will be way ahead of the learning curve. Often as I move the rod tip, I feel a bit of tension. This mushy feeling indicates to me that a bass has taken my offering. To set the hook, I reel in steadily and slowly lift the rod tip. This is almost exactly like the Slider hookset. The super sharp hooks penetrate with little effort.
This is also why I prefer nose hooked baits over a Texas rigged bait on this setup. With a Texas rigged drop shot, you must penetrate the plastic and the bass. Light line and the hard hookset necessary to do this will almost certainly break your line. With a nose-hooked bait, the bass get all of it every time and there is no need to over exert pressure on the line. When a bass is hooked, keep steady pressure on the fish. Slack line may result in you losing the fish.
ON THE WATER
The first thing I'll tell you is that this is a great way to catch a ton of fish. You likely won't catch big fish with any regularity but it is a great way to a limit and an occasional lunker. I used drop shot rigs en route to two tournament victories this past season. In one event, I realized quickly that it was the only way I was going to get a limit and it paid off with more than 10 pounds.
A word of caution: use a net. Do not try to hoist the fish over the side of the boat.
I prefer to use this method as a fun fishing technique. It can be devastating. This method can be used just about anywhere, in any type of water. I regularly employ it in early Spring, Summer, Fall and early Winter in stained water. It is not simply a clear water presentation.
For sheer fun, I love using it in small creeks for smallmouth bass. Here I'll use a smaller rod and cast the rig against the current. I stop the rig when it gets next to a large boulder or an area I think might hold a good fish. Here I want the bait to mimic a sculpin or madtom. I go with a short 6- or 8-inch tag end. I think this best duplicates the bottom dwelling baitfish. Smallies just destroy this set up.
DROP SHOT MODIFICATIONS
I'm always looking for new ways to make my presentations more effective and the drop shot rig has given me some pretty good ideas. On e of my best and most fun is a double shot rig. This consists of a small balsa shad fly tied about 6- to 8-inches above the standard hook. This fly can be purchased at BPS. It has a neat little hackle and a realistic balsa body and is a dead ringer for natural forage. I often utilize this on my UL set up for double smallie action. It is a panic when you get a double header.
I don't recommend the double rig for tournaments though. It is my belief that once you tie a knot above the Palomar that holds the hook, you substantially decrease the strength of the line. Fun only !!
DROP SHOT BAITS
I could likely talk about baits for weeks. Drop shot baits would be no exception. I've come to the realization that drop shot fishing is true finesse fishing. To me it would not be fun any other way. With this said, I stick with smaller baits. Very rarely, if ever, will I tie on lures longer than 4 inches on my drop shot rig.
I think I look at drop shotting as the last pure frontier in bass fishing. Not that I'm a purist but this technique is special to me. I am all for matching the baits I select, to the natural forage base of a particular water. It is a safe bet to assume that I do not use any wacky orange, pink or gaudy colored baits. Although I'm sure at one time or another they may actually work.
I rely on a small number of manufactured baits in my drop shot arsenal. The first baits are from that legend in plastics, Yamamoto. I really love the 30 series grub. This little grub is so natural and deadly when nose hooked. It is the first bait that I drop shotted with and it remains an integral piece of my approach. The 30 series grub is a perfect bait fish imitator. I like the salt n pepper and pearl gold/silver flake colors.
The next Yammie lure I use is the tiny Ika. This little gem was built with drop shot fishing in mind. I simply can't see many other uses for it. I like the fact that it is a thin bait with tails that give it a unique action. As always, I go for natural colors. Browns, greens and pearls are my choices.
Moving on, I use quite a few baits from Charlie Case. I absolutely kill with a small helgie fished in a tiny smallie creek. That bait is the most realistic of its kind. Case builds 'em right too. He offers quality baits in great colors at affordable prices.
The Case Madtom is another gem that I like to drop shot with. This bait is a killer Spring and early season lure when you know bass have been fighting off intruders to their nests. This on will readily get smacked despite being a bit bulky on the rig. Throw out a black or natural colored 'Tom and hold on, magic will happen.
Charlie recently sent me a mess of his new mini sticks. This is a Senko-type lure that is loaded with salt and has a good fall rate. Best of all is that it is by no means the frail, fragile lure like its prot�g�.
The last massed produced bait that I like is made by BPS. The 3 inch XPS shad is a perfect bottom dwelling bait fish bait. It has 3-D eyes and a small paddle tail. It is a natural for rigging through the nose. It has a little anise scent to it as well. I like this a bunch.
As you could have guessed, I make most of my own baits and hand pours are now my specialty. I started off using standard 4 inch finesse-type worms from Green Eyes Custom Worm Works. These worked well but I wanted something a bit smaller. I researched a ton of designs and came up with a prototype that we quickly made a mold out of. This was a 3 inch French fry bait that we put ribs on. I wanted it to be thin and flexible so we worked on shaping it just right. I opted for a French fry bait because I was planning on nose-hooking it. If it was consistent on both ends, I could get more mileage out of each bait by turning it around if it got roughed up.
I came up with the "Shot" worm. Down shot, split shot, drop shot, this bait was the perfect finesse worm for each of those applications. As I toyed around with it and caught fish on it, I wanted to give it a special kick. Something to make it better than other baits.
I had been making my own split shot worm for some time. This was a stick bait that I loaded up with salt and garlic/craw scent. It was a natural decision to apply that formula to the shot worm. I am more than pleased with the results.
When is the last time you made a lure that caught you a ton of bass? Better yet, when was the last time you made a lure that caught other guys a ton of bass and they told you about it? This is what my little hobby has become all about. Call it an ego thing but I love designing workable solutions to bass fishing.
By Craig De Fronzo
RODS
REELS
LINE
WEIGHTS
TYING THE RIG
WORKING THE RIG
ON THE WATER
DROP SHOT BAITS
