Daiwa’s NEW Versatile Tatula SV100 – Now With SV BOOST
Daiwa, an industry leader in fishing gear, has brought out a new iteration of one of its most popular and utility-based bait casting reels with the new Tatula SV100. This is a new and refreshed model of the Tatula that has been given several upgrades, now including the groundbreaking SV Boost System. This system utilizes a proprietary spool that has been paired with technology that helps make even newbie anglers cast like a Pro.
This low-mass technology greatly improves spool control to reduce backlashing and improve maximum casting distance. On top of the SV Boost System, the Tatula SV100 also comes with Daiwa’s Hydrive System, a tech system that has been pulled in directly from Daiwa’s flagship models, that gives the reel an improved housing and gearing system to make for a precise and smooth fishing reel.
“The new TATULA SV100 is an excellent multipurpose baitcasting reel,” said DAIWA Field Marketing Manager, Chris Martin. “It gives you a higher-end experience along with many of DAIWA’s top features and technologies at an attractive price.”
The new Tatula SV100 aims to be the new standard in baitcasting reels for getting learner anglers, that still offers top-quality features that more experienced baitcast reel users can enjoy and take advantage of. The Tatula SV100 will be available in 6 models with differing gear ratios and use applications, with all of them having an MSRP of $219.99
Daiwa Tatula SV100 Key Features
  • SV Boost System – Physics, sophisticated low-mass technology, and a specialized SV Spool combine to vastly improve backlash control, maximize casting distance, and advance casting accuracy, resulting in a reel that is easily operated by anglers of all skill levels.
  • Hyperdrive Armed Housing – A distortion-proof aluminum frame steadfastly houses the gear unit within the reel body. The concept comprises a combination of different manufacturing techniques, which considerably improve the functioning and lifespan of the reel.
  • Hyperdrive Digigear – A technology that makes gear teeth more efficient at transferring power, resulting in a smoother, more powerful gear set that also reduces gear noise. The gears are also strengthened by larger teeth in the traction wheel. And, the gearing has three points of contact – most gearing has only two – which keeps contact between the gear teeth, creating smoothness and longer gear life.
  • Hyperdrive Double Support – The pinion gear is mounted via a ball bearing at both sides, leading to a better and more even powered transmission from the handle. As well, the surface of the pinion gear is specially treated to prevent electrostatic corrosion.
  • Hyperdrive Tough Clutch – The clutch mechanics have been optimized to remain safely in position even on hard casts.
  • T-Wing System (TWS) – An innovative “T” shaped mechanical aperture that the line passes through when casting and retrieving baits, which allows the line to flow freely, reducing friction and sharp angles that slow line flow.
  • Ultimate Tournament Drag (UTD) – The sophisticated drag system uses carbon washers, alloy, stainless steel drag plates, and special lubricant to provide smooth performance. UTD prevents sticking when dragging starts and stable drag for the duration of fighting a fish.
  • Zero Adjuster – The spool tension knob comes ideally preset at the factory to match the model and reduce backlash when casting into the wind, skipping baits, or with lighter lures. However, anglers can fine-tune the spool tension to their personal preferences.
  • MSRP – $219.99
The post Daiwa’s NEW Versatile Tatula SV100 – Now With SV BOOST appeared first on OutdoorHub.
