- Apr 22, 2010
- BumFu*k, Egypt
Crashing Crankbaits
By Nick Ruiz
Nine out of ten times, when an angler hears the word "crankbait", the immediate picture that comes to mind is a large-lipped, deep-diver in a clear, obstruction-free, open-lake water. Not so. If by the end of this article, I manage to convince you that this is not the only application to use such crankbaits, then I have done my job. What we're discussing here just ain't your daddy's crankbaits, anymore!
The first time I used traditional crankbaits in heavy cover, the results were unbelievable. That experience entailed throwing a Worden's Timber Tiger (perfect for this application) into a venerable maze of standing timber and gigantic laydowns; something I thought at the time was just short of insane. I figured by doing this, I would run up a huge bill in the form of lost cranks. This tune immediately changed significantly when bass began literally coming out of the woodwork to slam the fleeing lure. Though as simple as it sounds, to throw cranks into cover, there is a certain amount of judgment and skill required to make a technique like this really work properly. With this tactic, location, as well as the actual type of physical cover, will both play a huge role in determining whether you're pulling bass out of the heavy stuff, or spending the rest of the afternoon in the tackle shop replacing lost lures.
First of all, we'll discuss the type of cover needed to perform this seemingly suicidal presentation. While the technique in theory can be applied to anything, some areas are better than others. I prefer large laydowns, standing timber, stumps, and a variety of man-made structures; the best of which by far is anchored docks and bridge support pylons. You'll usually want to avoid anything with a large amount of intricate tangles such as the end branches of laydown logs, cattails, bull rushes, and man-made Christmas tree-type reefs. Here is where a good pair of polarized sunglasses and a keen eye for productive cover will serve you more than well.
The basic technique, which I have learned through trial and error, is to intentionally "crash" crankbaits into large, solid pieces of structure. The purpose of which is to create the effect of a disoriented, fleeing baitfish, hell bent on escape from a predator. As it turns out, the number one reason for strikes for this presentation is usually not visual. Rather, the sound and more importantly the vibration produced when a crankbait comes in contact with various pieces of cover. A large crankbait speeding its way through a stump field, knocking and bouncing off wood makes quite a vibration and sound array underwater, which will travel 10 times father than it would above the surface. This is the equivalent of ringing an aquatic dinner bell for actively feeding fish. Of course each crankbait and each type of cover will produce a different sound pattern, but regardless, the idea is generally the same.
Experimenting with different baits in different situations will eventually yield a few front-runners that you will want to use all the time. For education sake, I will list my favorites but these are not even close to the tip of the iceberg, as undoubtedly each body of water will have its own top producers.
So far, I have found that the Bagley's Killr' B, the Poe's Competition Cedar, the Risto Rapala, and my personal favorite the Worden's Timber Tiger series, are a safe bet when fishing this method. If you are familiar with these baits, you might notice they share some design similarity. The importance not being in the body, but rather a very wide lip. The lip in this case is a bit more important than the body, as it is usually the lip that makes contact to the cover you are intentionally running it into. A wide lip will give maximum sound and vibration when contacting cover and will also deflect the rest of the bait clear which will prevent snagging as well as damage to the bait itself.
Another great bait to use with this method is the Poe's Pro Cedar crankbait series as I have used them frequently and have rarely had problems with them hanging up. In the rare occasion they do snag, the cedar is incredibly buoyant, and it will sometimes actually float free.
Finally, a bait that works extremely well in this situation is the hard-to-find Fred Arbogast "Mudbug" crankbait. This huge, metal lipped monster is perfectly suited for this method, as apparent from its design, and the testimony of those who use it.
As far as color, in this particular discipline of fishing, it's one of the least important factors in the equation. As long as the sound and action are there, the color is generally less important. A good rule of thumb is to keep the colors natural. Shad, sunfish, and perch patterns work well, even in the muddiest water. Again, sound being the big seller here.
While on the subject of running crankbaits into things, let me say that if there was a secret weapon hidden within a technique, it would be this: If by chance you come across metal pilings of any sort, FISH IT! Apparently the sound of a crankbait meeting metal overrides some sort of primeval instinct of the bass that just makes it want to kill that lure. I have had experience with smallmouth in a small river system, as well as largemouth in a lake chain, where metal bridge supports are common place, and the results are absolutely mind-boggling. Though I am not positive of what makes this so effective, my guess is that is has to be the sound. Like I mentioned earlier, apparently plastic on metal does something to bass that I wish all the other things we did to catch them did!
With this in mind, the next time you hit the water and the old stand-by's aren't paying off the way you'd like them to, consider "Crashing Crankbaits". You might be pleasantly surprised with the end results.
By Nick Ruiz
