Specifications:
- Length: 20′10″
- Length w/Trailer (swing Tongue): 24′8″
- Beam: 95″
- Width w/Trailer: 8′9″
- Persons: 5/870 lbs
- Aprox. Pre-Rigged Hull Wt: 2100 lbs
- Max HP: 300 HP
- Approx Fuel Capacity: 50 gal
- Livewell Capacity: 40 gal
- Approx. Front Fishing Deck: 43 sq ft
- Approx. Rear Fishing Deck: 20 sq ft
- Choice of - Three Color System (Gel or Polyflake)
- Hardwired Motorguide FW 71 FB 24V Trolling Motor (45″ shaft) - Port Side
- 6 Gauge Trolling Motor System (24V) with 50 Amp Breaker
Built-In, Recessed Trolling Motor Foot Pedal Tray - Built-In, Two-Bank Battery Charger
- Deluxe Instrument and Bow Panel with Soft Touch Switches
- Newly Designed Custom Dash with Soft Touch Switches
- Interior Lighting Package in Storage Boxes and Console
- Removable Navigation Lights with Storage Clips
- New BIOS 5″ Digital Gauges
- Lowrance LMS 480 with GPS in Dash
- Lowrance X-135 NMEA with Temp Probe on Bow Slope
- 800 GPH Manual Bilge Pump
- Dual Hi-Flow Recirc Aerator Pump with Hydro Air Tube and Timer
Freshwater Fill - Livewell Pump Out System
- Livewell System: 40 gallon Divided Livewell with Hydro Air and Aeration with Fresh Water
- Remote Livewell Drain Valve
- 40 Gallon Fuel Tank
- Windshield(s), Removable Tinted Plexiglas
- Teleflex Sea Star Pro Hydraulic Steering with Bulk Head Hoses
- Rigging Tube with Pull String
- 10″ R & R Manual Jack Plate with E Ladder
Ergonomic Steering Wheel - Built-In Removable Champion Measuring Board
- Retractable Rod Buckles
- Plier and Tool Holder
- Center Storage Tackle Organizer with Boxes
- Driver Key and Cell Phone Storage
- Mesh Storage in Rod Lockers
- Individual Three-Color Aqua Flex Shock Mitigating System Bucket Seats with Grab Rails
- Marine Upholstered Center Storage Box
- Matching Three Color (1) Fishing Seat / (1) Butt Seat with Hydraulic Power Pedestals
- Large Lockable Glove Box (DC Only)
- Carpeted Step-Up Insulated Cooler
- Stainless Steel Drink Holders
- Stainless Steel Pop-Up Cleats
- Built-in Battery Trays
- Carpeted- Lockable Rod Boxes with Gas Assist Lid Lifts and Insulated Alum Lids
- Lockable Front Storage with Gas Assist Lid Lifts and Insulated Alum Lids
- Passenger Rod Shelf with Rod Straps
- Plush Marine Carpet with Carpet Trim
Dual Transom Plates - Fire Extinguisher and Horn
- Rod Organizer - (mounted in portside)
- Stainless Steel Bow/Stern Eyes and Compartment Locks
- 12 Volt Cockpit Accessory Plug
Legendary V-Wing (Hand Laid) Hull Design - Stainless Steel Prop
- Lifetime Limited Warranty on the Hull with 3 Year Protection Plan on Selected Components
- 100% Composite Construction and Fiberglass Stringers
- Transhield Shipping Cover
- Newly Designed Modular Console(s)
- NMMA Certified and Coast Guard Compliant
- Choice of Factory Rigged Outboard
Tandem Axle Trailer with Disc Brakes
