Berkley Hotwire Line Cutter
A tool for the braid line era – but has several other uses.
Equipped with a replaceable tungsten tip that instantly heats up to 1200 degrees, HotWire Line Cutters cut and cauterize all types of line. The HotWire Line Cutter also repairs torn soft-plastic baits.
An LED task light is attached to the HotWire Line Cutter for cutting in the early morning hours or those late-night excursions. The safe-to-use line cutter is designed to retract the tungsten tip once the slide switch is released.
“I hate cutting through a superbraid only to have the end frayed,” said Boyd Duckett, Berkley Pro Team Member. “I usually have to re-cut and try to get a clean cut the second time around. With the HotWire Line Cutter I don’t encounter this problem. I can simply cut and go on about my business. Superbraids aren’t the only lines it can cut through; you name it and it will cut it.”
The HotWire Line Cutter is also useful in repairing plastic soft baits that have torn or broken. The heating element simply welds the worm, lizard and creature bait back into shape.The one-piece, compact line cutter has dual density SofTorx™ handles for secure non-slip handling. A single CR-1216 battery and two AA batteries power the HotWire Line Cutter.
This line cutter also welds damaged plastic soft baits back into shape.
Features:
Platform: Line Management
Cutting Features: Retractable Tungsten Tip (Heats up to 1200 degrees)
Attachments: LED Task Light
Powered: One CR-1216 battery (included) and two AA batteries (not included)
Tools: Heated Line Cutter
Warranty: One-year Limited
MSRP: $24.95
