Berkley Forward Braid – Unmatched Strength and Sensitivity
Berkley Fishing’s new high-performance braided fishing line, Berkley Forward Braid, is now available for purchase. Initially announced last summer at ICAST 2024, this is a new high-quality finesse-orientated braided fishing line with forward-facing sonar (FFS) applications in mind. This new braid uses a proprietary longitudinal construction method that makes a highly efficient line for fishing with forward-facing sonar and other finesse fishing methods. Along with the longitudinal construction of the line, it is thermally fused to keep the line’s round shape and have an ultra-smooth surface. These two features from the proprietary manufacturing method give this braided line incredibly low-stretch properties that improve the sensitivity of the line, letting anglers detect even the lightest bites.
Berkley Forward Braid’s thermally fused nature makes for a super thin line with an optimal sink rate and enhanced abrasion resistance to traditional braided lines. These factors together make for a line that lets anglers put lures right into the strike zone, which is essential for fishing with Forward Facing Sonar. Berkley Forward Braid is available in three color options, Lo-Vis Green, Crystal, and Flame Green, and is offered in both 150-yard spools (4–17 lb. test) and 1,500-yard spools (8–17 lb. test). MSRP is $29.99 for any 150-yard spools and $299.99 for the 1500-yard spools. This new braided fishing line is available now.
Berkley Forward Braid Key Features
  • Purpose Built for Forward-Facing Sonar Optimization
  • Proprietary Longitudinal Construction
  • Reduced Fiber Cross-over for Higher Sensitivity and Signal for Anglers
  • Smaller Diameter Line for Faster Sink Rate for Finesse Applications.
  • Enhanced Abrasion Resistance
  • Thermally Fused to Help Keep its Round Shape and Ultra-Smooth Surface.
  • Long casting
  • Available Colors – Crystal, Flame Green, Lo-Vis Green
  • Available Line Weights – 4lb, 6lb, 8lb, 10lb, 12lb, 14lb, 17lb
  • Line Diameter – .004″/.102mm, .005″/.127mm, .006″/.152mm, .007″/.178mm, .008″/.203, .009″/.223mm, .010″/.254mm
  • Available Spool Sizes – 150 yd/137 m, 1500 yd/ 1371 m
  • MSRP – $29.99 to $299.99
  • Available – Now
The post Berkley Forward Braid – Unmatched Strength and Sensitivity appeared first on OutdoorHub.
