Amazingly simple home remedies:
genxer36
Lord of Tomfoolery
Bethlehem, Georgia
THESE REALLY WORK!!
I checked this out on Snopes and it's for real!
AMAZINGLY SIMPLE HOME REMEDIES:
1. AVOID CUTTING YOURSELF WHEN SLICING VEGETABLES BY GETTING
SOMEONE ELSE TO HOLD THE VEGETABLES WHILE YOU CHOP.
2. AVOID ARGUMENTS WITH THE FEMALES ABOUT LIFTING THE TOILET
SEAT BY USING THE SINK.
3. FOR HIGH BLOOD PRESSURE SUFFERERS ~ SIMPLY CUT YOURSELF
AND BLEED FOR A FEW MINUTES, THUS REDUCING THE PRESSURE
ON YOUR VEINS. REMEMBER TO USE A TIMER.
4. A MOUSE TRAP PLACED ON TOP OF YOUR ALARM CLOCK WILL PREVENT
YOU FROM ROLLING OVER AND GOING BACK TO SLEEP AFTER YOU HIT
THE SNOOZE BUTTON.
5. IF YOU HAVE A BAD COUGH, TAKE A LARGE DOSE OF LAXATIVES.
THEN YOU'LL BE AFRAID TO COUGH.
6. YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT
DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE
AND DOES, USE THE DUCT TAPE.
7. IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL
PROBLEM.
THOUGHT FOR THE DAY:
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING
BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE
STAIRS.
