1. If you're choking on an ice cube, simply pour a cup of boiling water down your throat. Presto! The blockage will instantly remove itself.
2. Avoid cutting yourself when slicing vegetables by getting someone else to hold the vegetables while you chop.
3. Avoid arguments with the females about lifting the toilet seat by using the sink.
4. For high blood pressure sufferers ~ simply cut yourself and bleed for a few minutes, thus reducing the pressure on your veins. Remember to use a timer.
5. A mouse trap placed on top of your alarm clock will prevent you from rolling over and going back to sleep after you hit the snooze button.
